I recently bought a house with a Harman PB105 Pellet Boiler that provides heat and hot water along with an oil furnace. This forum was helpful in solving my first set of issues. Thanks! Now that I got the boiler cleaned and test fired for the coming winter, I have these mysterious issues:
![Harman PB 105 Pellet Boiler: Help solve some mysteries please Harman PB 105 Pellet Boiler: Help solve some mysteries please](https://www.hearth.com/talk/data/attachments/302/302156-4b0d6db7e74db86b8e77a1a36dbebaee.jpg)
- I have a seldom-used zone in my house for a work space adjacent to my garage. When we bought the house, the valves for the plumbing leading to that zone were closed. When I open them, the don't get hot when using the oil furnace alone. When I got the pellet burner working, I got heat to this zone for the first time, which was great. Except that the zone never turned off when the temperature exceeded the thermostat. Even turning the thermostat to the minimum temperature had no effect.
- At the same time, another zone (over the garage) also didn't turn off when the thermostat temperature was achieved.
- Some accompanying information:
- To solve my first set of issues, my plumber installed a new pressure relief valve, expansion tank and pressure/temperature gauge.
- When I look at the temperature/pressure gauge, it read 208 degrees (F). Pressure was about 20 psi.
- The outside temperature has been cold in the mornings (when I fired up the boiler) but balmy in the afternoons (60+ degrees).
- I talked to my plumber, who isn't that familiar with pellet boilers, who had these theories:
- The reason the two zones aren't turning off is that they are a "dump zone" for when the temperature gets too high. My gut sense is that 208 degrees is too high. I set the minimum temperature to 160 degrees and the maximum to 175. These are the settings when we bought the house. So, a readout of 208 seems like a problem.
- With the outdoor temperature so high, this might be driving the high temperature. I don't understand how this can be but I also see a table in my manual (p.23) that addresses "Pellet Boiler Outdoor Air Reset Operation", with seems to have adjustments for the outdoor air if you have an Outdoor Sensor. I don't know whether I have one of these are not. Could this be the source of this issue?
- The pellet feed rate is set at the middle of the range. I don't know what effect the pellet feed rate has on performance. Should I be changing this as the temperature outside goes up and down?
- I've uploaded a couple of pictures of the setup.
![Harman PB 105 Pellet Boiler: Help solve some mysteries please Harman PB 105 Pellet Boiler: Help solve some mysteries please](https://www.hearth.com/talk/data/attachments/302/302155-6018b8347f1296c8f3d08dca6ea14529.jpg)
