Harman P68 Wont Start
CoachRed74
1
Central PA
Hello, I have a Harman P68 pellet stove that is 5 years old...Has been cleaned regularly and have never had an issue before...
This past Saturday I left the house and it was running fine and when I returned a few hours later it wasn't running and no lights were on...After removing the access panels I found that the fuse on the board was blown...Of course I didn't have the correct size...On Sunday I decided to clean the stove since it was cooled down and I checked the combustion fan blade while cleaning and it moved free...I was able to find the correct fuse on Monday...Replaced the fuse and now I have the power light, status light and the combustion light comes on but the combustion motor does not run...Now could the motor be bad or could it be the control board?...Thanks for the help
Todd
One can make a power cord for the exhaust fan and power it directly from outlet. Better if you can plug into a surge strip with breaker and switch.
When was the last time you got behind the stove and blew out and evicted dust bunnies? Heat is the killer for the small motors and if the vents for them are plugged it toasts the windings:(
Good luck and Welcome to the site
New motor from Amazon as of this AM is 99.99
