Planning on doing my first burnpot replacement on my Harman P68 due to a breach in the metal by some of the air holes that’s causing it to split open but have a couple questions before I start in on it...any advice, as always, is greatly appreciated..
1) obviously the igniter and igniter cradle will have to be removed from the old burnpot, but is there a way to remove the burnpot and subsequently have the igniter and cradle be removed from the rear of the burnpot instead of the front or is the circular opening at the rear too small? I’m not trying to cut corners but I’m just wondering if that is an option.
2) the burnpot has been in there for 3 years. I ordered a gasket along with the burnpot to replace that as well while it’s out. The removal looks to be straightforward but I don’t want to assume that (usually after saying something like that the work time doubles from what I originally figured). Should I be aware of any obstacles other than the removal of the pot from the mounting bolts and the subsequent installation of the new pot onto the bolts?
thanks again for everyone’s help.
