I have a Harman p68 and at the end of this season, I will be replacing the burnpot for the THIRD time due to metal deterioration. I assume this is not normal and I’m getting tired of buying and replacing them!
FYI: A similar burnpot issue was discussed in this thread (01/2022): https://www.hearth.com/talk/threads/harman-p68-firepot-help.190694/ - but the cause was not determined.
After less than two years of use, the first burnpot was replaced by my local Harman dealer under warranty in 2015. The dealer said the burnpot must be defective.:
Four years later, the next burnpot was replaced by me in 2019:
Now, three years later, the burnpot is deforming again and will need to be replaced. Notice the raised mound:
It may not look like it, but the burnpot gets a daily scraping and then a thorough scraping/cleaning appox. every four weeks.
As for causes.. About the only thing I can come up with is the OAK (outside air kit) is bringing moist air in from the outside and causing rust in the burnpot (though I do not see rust elsewhere inside the stove). While the stove is running, of course the burnpot is very hot and any moisture should be immediately evaporated.. but that’s the only thing I can think of.
Should I try periodically oiling the burnpot with something (not WD40, my wife is chemically sensitive)? Or perhaps disconnect the OAK completely?
Thanks for any help.
