Greetings Newbie to forums here.
I've had my P61a for 3 years now. I try to maintain the dickens out of it. Gets a yearly cleaning once a month.
Help me out with a few questions.
(note stove is vented with proper pipe to a cleanout tee up 7 feet to 90 and out through a 3 ft pipe which passes through the cold air intake thimble.
In basement of cape cod home heating basement and main floor with it.
How often should I change the ESP? Seems I have to do it yearly. It is always kept clean but often I get Really poor performance, that seems to fix it.
Normal setting for feed rate - I see people here at 4, I'm generally around 2
Current issue- TONS of ash, decent flame but low heat. (full clean out last Saturday).
Settings
Room temp maxed
Feed rate 1.75+-
Stove temp maxed
Pellets are from local mill in Holland MI Supposedly hardwood blend. Dealer has sold them for two years, always a little ashy but not like this and lots more heat.
Thanks bunches!
Settings
Room temp maxed
Feed rate 1.75+-
Stove temp maxed
Thanks bunches!
