Harman P61a Burn On/Off Burn Cycle
rico7684
39
Finger Lakes, NY
I have a new P61a, which cycles on and off frequently after reaching room temperature. It burns on high, tapers off to a more moderate burn, then shuts off and then repeats the cycle. I previously had a P61a for many years, which would burn on high, taper off and then burn at a low temperature steadily. I don't remember the older stove cycling on/off like this one.
This unit does not seem to operate like the old unit did (or maybe my memory doesn't). I have placed the temperature sensor wire in various places in the room, yet same results. The feed rate appears to be correct and it is burning pellets properly, it's just the constant on/off cycle which I'm not used to with the old unit.
Any ideas if this is working properly, and if not, any ideas as to how to resolve it?
A forward thanks for all help!
Check your manual page 12 /13 tells you what you wish to know
Depending on the age of your old P61a, the new one will have the updated board as well, the burn cycles are slightly different.
Is the room much smaller than the room you had one in before? Maybe the stove is overshooting room temp due to the area being to small for the feed rate? The stove will slow the feed as it gets close to the set temp then idol for awhile if temp is met and stays met. Maybe it is going way over then shutting down? Turn feed rate down 1 point and see what happens
Thank you everyone. The updated board/burn cycles may be the difference as it does not cycle like my 2010 model. I'll also check the feed rate.
What version is the board? I replaced my 06 FS Accentra board and the new version shut the stove off rather than go into idle mode on room temp/auto.
Room temp/switch turned to auto---stove starts and stops
Room temp/switch to manual---stove goes high to low,stays running
Almost every Harman ever made,for years
Read the manual
Not only have I read the manual, I've had an older one for ten years. The question was regarding this new one & the on/off cycle that is different than the old one, so thank you very little BB
"I previously had a P61a for many years, which would burn on high, taper off and then burn at a low temperature steadily. " your words. Have a nice life.
Reactions: johneh
