Hello,
Purchased used 3heating seasons ago. It’s been pretty good with an occasional quirk that worked itself out here and there.
1998 manual ignition.
Extremely clean from the chimney cap to the ash pan.
3 blink status after last cleaning in march 25
Replaced esp black wire oem: no change
Brand new installed:
Combustion blower
Distribution blower
Exhaust fan blade
Control board
Vacuum pump pressure switch
=no change
Replaced:
Hopper gasket
Door gasket
Ash pan door gasket
Checked fines door gasket: good
No change
The P 61 powers up gives a three blank status and behaves like it’s in test mode. All of this while the knob is turned to off. It will not shut down. I purchased all of my equipment through East Coast hearth. It’s all OEM and all of the model numbers have been checked and are correct replacements.
As you can see the only thing I haven’t replaced is the auger motor, which is working fine.
Any suggestions from anyone who has experienced the same type symptoms?
I’m out of ideas what to do.
Thank you
I did see a post in 2018 with only two replies. Member from Wilton, Maine,had the exact same Stove the exact same manufacture year and the exact same problem. I tried to direct message, but apparently that member has left the forum..
Combustion blower
Distribution blower
Exhaust fan blade
Control board
=no change
Replaced:
Hopper gasket
Door gasket
Ash pan door gasket
No change
Thank you
