Harman P61 Fan Direction
Napali
3
Vermont
Just installed a new exhaust fan on my Harman P61 (and cleaned out the distribution fan since everything was open). As the wire colors don't match up with the stove, I am trying to determine the correct way to connect. Ignoring the ground, the wiring connecting the remaining two wires will just determine which way the fan spins. And that is my question. When facing the fan from the ash chamber, should the fan be spinning clockwise or counterclockwise? I don't feel much of a breeze either way so want to make sure I'm correct before turning the stove back on. Thanks in advance.
It’s not a 3 phase, which ever way will work as long as you have the ground on properly
Does not matter. As long as ground goes to ground
Reactions: Washed-Up
Thanks for the confirmation. That explains why I feel no change in air flow when swapping wires. Time to fire it back up!
