A friend of mine has a P61. Is it normal if the flame is blue. Maybe 2 inches high from the bottom?
forgot to mention that my blue is deff never 2" high,,,When my flames are running high, I usually have some blue at bottom.. white yellow rest of the way..
As bioburner notes, I would bet on possibly copper being the source of the blue flame.A friend of mine has a P61. Is it normal if the flame is blue. Maybe 2 inches high from the bottom?
Some conifers have a high amount of copper sulfate. Makes for a good fungus killer too. Had a bad problem with fungus on peonies last season. If you ever buy color crystals for sprinkling on a fire that's what it is.
If we are gonna make Gourmet pellets, I want them to smell like stuff, Steak house, Coffee, Bread baking, Pie in the Oven, the list is endless, we can call them smellets![]()
EXACTLYI usually get an inch or so of blue flame in the P61 with some hardwood pellets. Less so with softwood. Also after a full cleaning I can get a little space between the pellets and the start of the flame on ramp up of flame after first ignition. Right now, this minute, I have a mixed blue and yellow flame dancing over the pellets on a low burn with Energex Hardwood. When this ramps up for heat I will have a lot of yellow flame over a blue base. I take this as all good, I consider that a clean flame. There is plenty of ash in those Energex but the flame is clean.
The hottest portion of a flame is blue. As it gets cooler it moves to yellow, orange, then red. The clear area is due to high temperature gasification of the fuel before ignition. Some other colors can be attributed to constituents of the fuel itself. In short, blue is good. So is light yellow.EXACTLY!!
Energex Hardwood and Maine Woods Blend both have given me a blue base to the flame. I don't recall off hand what other brands have done this. I'm burning the Energex now and a time last winter as well. The blue base to the flame is what drew me back to them. Incidentally both brands have their share of ash content. I'm thinking that also Tractor Supply's hardwood did this as well but that's a bit of fuzzy thinking, though I know they burned real hot..Blue is good. I have had one brand that can only get to green. It is the pellet content. My guess on my green is bug remnants in the pellets from ash bore trees that have been infected. Hotter for me and good use of damaged trees. If you have blue then good for you and never change brands. One hot pellet.
