Some background, I will try to be brief, my question will follow.
I Have a 10 year old Harman p61-a. Awesome stove. Over the 10 years I have learned a lot mostly here, but it's been a while. I'm very particular about keeping it performing like a formula one race car. I do a full clean about once a week. I like to see the flame so bright you see spots after watching it. I run only in stove temp mode, usually blower high. I measure my output temp with an ir heat gun on the same spot near centre above door by heat exchanger hole to ensure I'm where I want to be according to outside temp.
As the temps have gotten colder the last month, and I've turned to temp up, I've been having a problem with low heat output per what is normal for setting, weird feeding, ramp up to big flames, back off low, and repeat. Output temp varies by 20c. Normally it wouldn't vary much more than 5c. Also ash started staying in pot, overnight would fill up, somewhat lazy flame creating some and black soot on firebox. (I always try to keep it burning good to have white fluff on sides, I hate seeing black). Normally ash just stays in corners,unless stove needs a cleaning. Very rarely do I get any black soot unless stove is nearly maxed out a few rare extremely cold nights.
So this has been bothering me, I have been tinkering, checking seals, exhaust motor, cleaned several times over, switched probe, tried different pellets, everything I have encountered or learned over my 10yrs experience. talked to my very helpful dealer on several occasions. We ruled everything out, and decided to try a new board.
Well, I hooked the new board up and wow! Is there ever a difference. It is running WAY hotter on the same temp settings, and doing so with a much smaller flame. My concern is that it is running too hot, and I may have fluked out and got a dud board. For example, previously on my original board, pretty consistently on #6 I would read around 310c, this was my target on super cold nights. Well on this new board I'm hitting 310c at #4. To the other side, on #1 I would read around 140c with old board, new board 210c. I'm fine if it is just an updated board and things work differently and more efficiently. I just find it very strange that I'm getting an output temp on #4 that I would have previously got just below max. Also with new board on 4, flames are licking the exchanger, I don't know what they would do on max, I'm nervous to try. I know the esp will shut things down when it gets too hot, but I have a feeling that would be way before max setting on temp dial, unless of course my normal understandin for 10yrs was all wrong.
Maybe if anyone else uses heat guns they could throw some temps at me that they read on certain settings in stove temp mode, dist. fan high. Any feedback would be greatly appreciated.
Thanks
Thanks
