OK I'm new to a pellet stove...My mother just purchased one and it was a joint effort between my brother and I to install.
It was a normal install into an exsisting fireplace hearth. We set up a new hearth pad and ran the pipe straight out the back
and up and into a block off plate.
Put it all together, plugged it in and filled up the hopper. ran the test mode to make sure all the "Fans" and auger was feeding
properly. So far so good. I added a decent hand full of pellets to the burn pot. Added some "gel" starter fluid. Lit the gel and closed the door and waited a few minuets for the gel to get the pellets started, than turned on the feed to position 1. After about 5 min. the pellets slowly go out. This process was tried 5 time with the same results.
I checked the chimney for no blockage ---- it will suck a candle out when I place it near the the exit pipe of the stove with the pipe disconnected from the stove. I can feel a fair amount of air flowing from the stove exhaust exit with the pipe disconnected.
The air exiting will increase when I turn up the feed rate.
Please help, Mom is really upset, and you all know how moms can be...any ideas are welcome...
Thanks
Thanks
