Hello,
I am looking for help with my Harman P38 control board upgrade. I bought it a year ago and I am finally getting to install it and I am hung up on the wiring to the feeder/auger motor.
I went to install the upgrade kit and I am stuck when it comes to the wiring for the feeder auger motor along with the low pressure switch.
The new wiring has a female crimp connector on the white wire at pin 6, trying to connect this to the white wire going to the feeder auger motor will not connect because the crimp on connector is also a female crimp on connector on the cable coming from the feeder auger motor.
I have the wiring diagram.
I also don't know if I need to use the optional Blue Jumper for the pressure switch.
Does anyone know if there is a video of installing the wiring. I have everything else wired except for the auger and the pressure switch.
Thank you
Thank you
