Hello everyone,
I searched everywhere trying to find out what is wrong with my pellet stove but the symptoms have changed a few times and I am not knowledgeable enough to know what they mean. It started out 3 days ago. We woke up and the stove was completely off. I took it apart and noticed that the fuse was blown. Replaced the 6a 250v fuse and it blew immediately after turning on. After reading some, we found the ignitor to be a common reason for this so we purchases an OEM ignitor. Installed the ignitor, put a new fuse in, and it started up no problem. Ran for about 5 minutes and the fuse blew again. So we tried to manually light the stove with the yellow ignitor wire disconnected to see if that was the cause of the fuse blowing. The stove runs now without the ignitor connected but the distribution blower runs for 30 seconds, then shuts off for 2 minutes. The timing of this is consistent and almost exact. Also, the "room temp" feature can be set to control how hard the distribution fan blows but no matter if it is low or high, it blows the same. So it appears this isn't working other than the fact that it must on in order to have the stove running at all. If we had it in the off position, the stove would not light since there is no combustion blower running. At this point I am thinking it may be the control panel but before spending over $200 I was hoping someone here could tell me what I can test or check to make sure. Another thought was the ESP probe but I am not really sure. Thanks in advance for the help.
