Harman P-68 Control Board Dip switch Settings
ScottyDaug
75
Maine
Hello,
I just received a new control board for a P-68 which I will be installing. The dip switches need to be set for the correct model. The sheet that has the settings has two options for the P-68, P-68 UL Feeder 6 RPM, and P-68 -2 Feeder 4 RPM. Is this the older chain drive feed system vs the new system? How do I know which settings to use? I would be thankful for some guidance.
Thank You,
Scott
In the back of your manual you should have a parts list, it might tell you what auger motor you have. If you don't have a manual, go to Harman's website and look it up under P68 manual.
Thank you MSmith.
Need to know which RPM auger motor is on your stove.
  • scan0002.pdf
I dont remember a p-68 having a chaindrive? The p68 just went to a 6rpm motor about 3 yrs ago i think
