just picked up a used harman invincable insert ...its a manual start with gel...... can this be converted to run automatic with a thermostat???
pellets101 said:just picked up a used harman invincable insert ...its a manual start with gel...... can this be converted to run automatic with a thermostat???
pellets101 said:getting a clicking sound from feed assy arm & spring and slide plate??
how long does this thing take to shut down when you select it to off.... i have a whitfield that shuts off pretty much in a few min
does the fire pot stay full of ashes after it shuts down??
Don2222 said:pellets101 said:just picked up a used harman invincable insert ...its a manual start with gel...... can this be converted to run automatic with a thermostat???
The manual states that all you need to do this is the room sensing probe!
pellets101 said:how do i check the auger motor its working but im getting a loud bang from the slide plate & if i grab the auger shaft i have a good bit of play (harman invinceable insert)
pellets101 said:there is a spring & arm that is on a cam that pushes the slide bar that drops the pellets as the slide bar moves back it almost seems like it jumps at some point during the cycle i noticed some play in the auger shaft ...thanks for any input , it happens every revolution of the cam cycle...i was wondering if it was normal because it would seem to help pellets drop but it does happen every revolution
