Thats a start..thanksA perfectly new red wire esp reads about 1.1 k ohm (at about 70 F). This will change with temperature since that's what it does... I would guess a bad one would show open..
A Harman DDM.
yes with an electrical multimeter you can test all the harman temp probes. red ones are as lbcynya said, between 1,000 to 1,100 ohms of resistance depending on what your room temp is (remember if the stove has been off for a while the probe may be much colder from the cold air outside coming through the pipe, i typically take them out to test them between 67-72 degrees)
All other ESP probes that are NOT red should read around 650,000 to 550,000 ohms resistance, and lastly the room sensing probe should be around 3,600 to 3,300 ohms resistance.
After taking a good initial read you can breath on them or use any heat source and the resistance should lower as the probe heats up except the red which should rise, hope this helps.
is the probe red or the wires...mine has a red and black wirered ones??
Will that work on a 2 knob board with no DDM plug?? Can you check the ESP by itself or will it plug into the back of the board and act like an ESP ???
depends on the P38....3 knob board, you can plug the DDM into......2 knob board (old TURBO boards)....cant plug the DDM into, so, no
Digital Diagnostic Module........your friendly dashing Harman dealer can probably sell you one, part number 3-40-05401, several hundred bucks or so....whats a DDM??? If its for testing a Harman stove where can I buy it and how much $$$![]()
Last year I was quoted around $350.00 but I decided I really didn't need one because I have a multi-meter and I know how to use it to troubleshoot.whats a DDM??? If its for testing a Harman stove where can I buy it and how much $$$![]()
yea....methinks it'd be a waste of $350 or so......check yo ESP probe for cleaning
So the red wire will work on 2 knob board if you change dip switch setting, correct?? Just for the heck of it I have the black wire ESP, 2 knob board.. Thinking of getting spare..If replacing a black wire with a red wire probe in any of the other harman units, be mindful of dip switch setting number 5...needs to be ON for a red wire, and OFF for a black wire ESP probe..
I had the same issue with my Accentra insert over the weekend - 3 flashes, but I also had a very slow-to-start distribution fan.
So I cleaned the ESP and the whole stove really well, then pulled the distribution fan and cleaned it from top to bottom. So far, the problem has not cropped up again, but I fear my ESP is bad - hence the iffy performance of the distribution fan.
Any thoughts on my analysis?
