Harman Canadian parts supplier?
Washed-Up
1,248
Kananaskis,Alberta, Canada
Are there any Canucks here that use a Canadian Harman parts supplier? And who is the best Harman parts supplier down in the states for you fellas...price...availability etc...thanks in advance.
You can use whatever screws you want as long as the thread is identical.
The configuration of the head may need to be similar, for clearance issues, but a thread is a thread.
I sincerely doubt they are made from cast iron. It's too brittle for that application...
Use a steel screw & put some anti-seize compound on the threads before assembly.
That should make the NEXT disassembly a little easier.
Reactions: Washed-Up
