- Nov 12, 2006
- 117
I bought a Harman Advance last fall. I installed with the help of a friend in the buisness. We did the draft checks and adjusted. Draft is on the high side, 18' of 4" pipe. It ran great other than a noisy/vibrating auger motor that was replaced, no problems.
This heating season I had found a "dead spot" in the temp dial at about 74 deg. where the stove would just shut down into idle mode. This dead spot has increased in range overtime. Sometimes I can just tap the end of the knob and the stove will take off and heat, sometimes not, sometimes for a little while.
It seems like to me a no brainer that the temp. pot has a problem. My dealer is at a loss. I carefully suggested my theory. The dealer contacted the factory and they told me to clean the stove, clean the exh. temp probe, and move the room sensor farther away, so I did.
Suprise! Same problem, but last night I noticed the dist. blower "hunting" in low fire mode. Up down, in between, several times in a few minutes like it can't decide where it wants to be, very irritating. I moved the temp dial down just a hair and it settled down to a steady speed. My wife complained of this problem in the past, but I blew her off.
I'm getting a little nervous as the heating season is ending and my 3 year warranty will end this fall.
Geez! Why didn't I get a Crossfire like my a freind suggested
Any help?
Any help?
