Harman Adavance-2 feeder weldment replacement which weldment do I need to get?
zinger827
45
Maine
I have the indirect drive as see in pic with auger motor and auger removed.
But mine has the fines door wingnut on bottom?
I see the difference is my air box that feeds air to glass cleaner is on edge instead of flat like the
Harman Feeder Body Weldment: 1-10-677150​
This can be fixed quite easily by pulling the firepot (which you already did) and bending a U shaped piece of metal to place under worn feeder tube. With metal jammed against bottom of tube, weld it in place and then grind opening to close to OE size. Suspect the auger tip wore down and allowed fire to burn into tube area, or feed rate was set too low (1-2). Definitely replace auger afterwards.
