My Harman 52i-TC is only 3 years old.
If i turn on my pellet stove it disregards the temp I set and heats the room way hotter then I want.
Even if i switch to manual mode it has no effect.
If I hit the shutdown button it refuses to shut down until its run out of pellets.
I had my Platinum dealer come by and they cleaned the entire unit ($250) and said that'll fix the problem... it didnt (It worked properly for a couple days)
I called back and they now said I needed the wireless room sensor ($200) and that'll fix the problem... it didnt
They have no idea how to troubleshoot the problem and have now ghosted me.
I've seen similar posts where people say its the esp probe. Yesterday I cleaned the probe and it seemed to actually work but that lasted less then a day. And now i'm back to where I started.
When I go into the diagnostics I can see that the ESP is reading a temp of 400-413 degrees so I assume that the probe is not the problem since im getting readouts??
I dont want to just keep buying parts hoping that it fixes my stove. Im hoping there is a logic based way to diagnose this rather then just guessing.
If anyone has insight it would be very much appreciated.
