Was wondering if anyone might know the answer to this question, I had to replace my control board (did replace with a new OEM one) now stove seems to come on even when the temp is set to 50 degrees and it is 72 in house and does once house reaches around 76-77 degrees begins it's ramp down and shut off mode. I decided for the heck of it to use my multimeter and test the resistance of the room temp sensor and at 72 degrees in the room it was reading over 7500 ohms which I thinking sounds high. Does anyone know what the sensor should read approximately and if so am I correct that my reading seems high? I did btw tested the resistance while holding the sensor in my hand and the readings di begin to go down but after maybe 2 minutes or so it only went down to 5900 ohms. If this isn't the issue could it maybe be a bad control board? I know with the old board I had to have the stove set to around 57 degrees to keep it 72 in the house so I know the temp sensor isn't the most accurate as I have used a laser temp gauge to check the area the room sensor was against the temp at my house thermostat and the areas were both reasonably close , oh and the reason for changing was the off setting on the stove temp/ room temp wouldn't always shut down the stove completely once coming home and the stove was running without the blower and cast was fiery hot.
