This is my first year with my new Accentra & I was wondering what settings I would use to get the minimum .75lb/hr feed rate.
I have done alot of research on this site & everyone says the most efficient way to run it is in room temp mode so the stove cycles on & off as needed. I have been using the room temp mode set around 68 & been averaging a bag a day usage.
I switched over to stove temp today & have it set at 1 & the house is getting warmer than it was. If im using stove temp mode on setting 1 is that the minimum feed rate?
