Mostly have been running in stove temp mode and since day 1 even at highest settings could not get feed rate to increase, pellets always within couple+ inches of pot edge, heat was fine so ignored it. Recently tried room temp control and can't get feed rate to decrease, pellets practically (some do) overflowing the burn pot. Have ran in room temp mode occassionally prior without the overflow problem. Possible I could have pinched a wire last time I had it out.
Feed rate test function does work so know this pot does something. Stove does get weekly cleanings for everything short of pulling it out which is done annually. In reading the manual appears I'm running with a return air sensor setup.
Appreciate any help or places to start looking, thanks
