Harman Accentra Insert Flame Issues
STLSully
10
Massachusetts
I have a 2006 Harman Accentra Insert that has worked beautifully for me. I typically do a full cleaning after every ton. At the end of last season, I must have been distracted because I didn't do a full cleaning. Fast forward six months. I did a full cleaning before firing up the stove. I made sure the igniter area was clean of fines. I cleaned the side areas to the best of my ability with the long thin bristle brush and vacuumed everything that came out.
She ignited right up. I set her on stove temp, as usual. The issue is my feed rate has to be at 6 to maintain a flame. Additionally, the blower is very loud and the flame sits in the very back of the burn pot. I am used to sparks dancing around at ignition, but now it happens constantly. In an effort to fix the issue, I replaced the gasket around the door. It was definitely compromised because I found ash on the outside of the stove. That did not fix the flame issue. I made sure the probe was in good shape. It is. One odd thing...I was going to try the stove on Room Temp and I discovered my room temp sensor was damaged. I think my cat chewed on it. I'm uploading a video. It is producing good heat, but I know this isn't the way this stove typically burns. Any help is much appreciated.
next time you fire up the stove check that the auger is turning at the correct speed. Should make a revolution every 15 seconds. Also empty the hopper and make sure there is not something partly blocking the slide plate. I have seen this same issue and there was a piece of cardboard restricting the amount of pellets coming in.
Any more updates on this ? I'm having a similar issue. No problems all winter and today I watched the flame start to die down and then just cherry red pellets and no flame
