Hello all,
I ordered a replacement ignitor for my 2005-2006 Accentra2 and installed it this weekend. Fairly straighforward on the whole job but after having everything back together I see a single quick blink on the motor control board lamp and then nothing else, the combustion motor lamp. No start in Auto mode.
It will go through the usual sequence in Manual mode.
Normally when lighting with Auto mode there are one, then two blinks up and then finally the ignitor lamp lights up, totalling three in all. I rechecked my connections and thinking they may have been reversed, I switched them with the same result. I did check to make sure the ignitor works off the stove before I started this install and it did indeed get hot!
Does anyone know what a single lamp flash when in Auto mode on the motor light mean? I do not see this listed in the manual
Help please! ![exclaim ;ex ;ex](/talk/styles/default/xenforo/smileys/exclaim.gif)
![Confused :confused: :confused:](/talk/styles/default/xenforo/smileys/confused.gif)
![question ;? ;?](/talk/styles/default/xenforo/smileys/question.gif)
