Harman Accentra FS troubleshooting
ejsechler
64
North East Ohio
Having a issue with my accentra. On intial startup everything seems to start and work fine. After 30 min I am getting 5 blinking lights. Which leads to ignitor issues from my understanding. Well the ignitor works so I don't under stand that but it also will not fee pellets after the intial start up. I bought a new vacuum switch and that did not fix the issue I tried jumping the switch and that also does not do nothing. When I run test mode everything seems to work and come on feeder combustion, and distribution blower all works. Can you point me in the right direction to try next please?
Is there a fire in the burn pot? As in do the pellets catch on fire? If so pull the ESP and clean it and reinsert. 5 blinking lights means the ESP did not sense fire within 36 minutes of start up if fire was present.
Reactions: johneh
Had a spare esp swapped it out. Pellet stove seems to be feeding and running correctly now. Thank you ARC.
Reactions: ARC
Well take that back I spoke to soon. Changed the esp started up the stove everything fired up as normal and now the feed light comes on but not pellets are being feed. With a fire going in the burn pot. Seems to be happening about 40min into a burn
