Harman Accentra 52i question
JRS
9
PA
Hi, I'll be purchasing a 52i and had a question.
Does this insert have some kind of slide mechanism built in, to make it easier to pull out for maintenance? I also see that Harman sells an accessory rail kit, so it's not clear if that would be needed as well, or if there's a better (cheaper) approach..
This will be installed in a fireplace with a raised hearth.
Thanks in advance!
Thanks in advance!
The Accentra has a rail system built into the unit. If you have a raised hearth, there is an optional stand the unit slides out and on to. If you have a hearth that is level to the floor, you do not need the stand.
I include a picture of my raised hearth and the cat is about to demonstrate the ease of sliding the unit out - not. But at least with the Accentra, you have the ability to access for cleaning.
  • Harman Accentra 52i question
