Hi all!
Bought a house this summer that had a Harman P43 installed already. When it wasn't too cold, it burned just fine and I had no issues with it.
Recently (as in the past 2 weeks) the stove has been having issues. The feed limit is set to 25%, but it continuously pushes the pellets out of the burn pot and into the ash pan, so the combustion of the pellets occurs in the ash pan. I have tried cleaning it, resetting all the factory defaults, etc. But it still continues to burn in the ash pan. The only way it wont is to leave it in "Test Mode" and manually advance the pellets by myself using the test features. Any help would be greatly appreciated, as this stove is our primary heat source for what is looking to be a cold winter. I am used to wood burning stoves and fireplace inserts, so this is all quite new (and majorly annoying to me)
Also, the igniter does not work, even though we have replaced it. The stove does not self ignite, I have to use gel fire starter on it every morning to get it lit. Any ideas on fixing that?
Thank you!
Thank you!
