Harman Absolute 43 Constant Overheat
ESteele
4
Catskill NY
Hi All,
My 8 year old Harman Absolute 43 has been working well this season up until a week ago. It would not should down, neither from lowering the room temp sensor nor from hitting shut down.
It then started to consistently be on the highest heat setting, a massive flame 24 hrs a day. This was constant wether I had it on low constant burn or on a low temp setting.
A couple days ago it overshot the ESP temp limit of 470 and hit 520 degrees, which caused some fan malfunctions. I opened the hopper to let the flame die down. After this I cleaned the ESP sensor (another startup gave the same overheating results), and went as far as had a tech come out and give an opinion.
The tech cleaned out the ventilation system inside and out, and after startup it overheated again stuck at high temp. I’ve been told it may be a control board.
I have now noticed that the pressure switch says closed every time I look into the diagnostics. Could this have anything to do with overheating? Looking for any smaller fixes before buying the expensive board.
A vacuum switch failure will eventually shut the stove off. Not allowing the auger to run and then starves the stove of pellets. It sounds like something failed on the board. Im not a Harman guy but im sure they will post when they see it.
Reactions: ESteele
Is the stove plugged into a surge protector?
No surge protector, we had a small blip in power a day or so before I noticed the symptoms.
You may have taken a power surge through the board
This would allow the Majic smoke to escape
Believe it or not electronics are very sensative. A stray millivolt can let the magic smoke out. Boards are divided in two low voltage on one side and line voltage on the other. They are usually separated by optoisolators and diodes. One good spike will do damage before a fuse will blow. Sorry to hear its not a cheap fix.
At least I know how to prevent this in the future…. Thanks y’all. I’ll update when the new board goes in.
Reactions: Ssyko
Also, if you want to run in the Catskills (beautiful place been there) during a power blip or outage without the control board even knowing, then invest in a sine wave inverter (1000W lots) 12V Battery, and 30A battery charger. Run it on the UPS all the time. (You will need a generator or solar system to keep running) Oh I see you have lots of generators ! The battery you want would be deep cycle or AGM
I forgot to mention you should add a SPD to your panel and start protecting all the electronics in your house/garage. I recently installed a Leviton R2120-B
A suggestion Friendly fires in Ontario most likely have the board you need
and with the exchange rate now the cost is about 40% less using American Dollars
They do ship to The USA
Reactions: ABusWrench
Search for a Tripp lite iso bar surge protecter been running mine almost 10 yrs now 👍👍
[Hearth.com] Harman Absolute 43 Constant Overheat
Yes please do, as I just got a P43 and will be doing my own maintenance and troubleshooting. I have most parts as spares except for the control card and dist blower. If I were you, I'd get spares because if you don't have them you can't fix it and find out what is really wrong.
As far as my dealer here they did a good install but there is where the support will end. Harman say they have this great warranty but then they say the dealer must provide all warranty - forget it
