Prefacing this by saying I’ve never messed with a wood boiler before. And I don’t need this set up for my water heater. Just trying to get it going for heat. Manual: http://www.hardyheater.com/Pdf/H2-H4-A.pdf (I am pretty sure anyway; this doesn’t have a product number on it, just a serial number lol).
Supposedly this wood boiler was running just a little over a year ago. The pipes are burst, and when I opened it to try soldering it, I was just straight up confused by what is going on inside. I watched a lot of videos, read the manual. I think I’ve mostly made sense of it, but….
Am I crazy, or are these three different pumps? I am assuming the two on the left got bypassed. The cords to them isn’t wired to anything. Only the one on the right is.
Close ups of each one:
My second question is…. I am wondering if I can just cut out 50% of this. What confuses me is that the bottom valve is the return from the radiator — the cooler side of the return? (Getting this from: ) Mine is connected to the pump, too.
Yellow leads from the valve at the bottom, to the return from the radiator. Pink is how it connects to the pump. My understanding is that the yellow should go into the bottom valve — to return into the wood boiler. Then it gets heated, and sucked back out by that pump to return to the radiator with hot water.
So can I just cut out/remove everything that’s green/yellow in this pic, and connect the radiator return directly to the bottom valve?
Here is a pic with no markings:
I also attached all these files to the post but I thought Imgur made the reference easier.
![Hardy H2 — is this 3 separated pumps? Hardy H2 — is this 3 separated pumps?](https://www.hearth.com/talk/data/attachments/314/314625-d974cc5b31268e6857f9562511f47f8d.jpg)
![Hardy H2 — is this 3 separated pumps? Hardy H2 — is this 3 separated pumps?](https://www.hearth.com/talk/data/attachments/314/314622-30e55aa292cba5c3bd4bf132c85f3d5e.jpg)
![Hardy H2 — is this 3 separated pumps? Hardy H2 — is this 3 separated pumps?](https://www.hearth.com/talk/data/attachments/314/314623-414bb53ef14b765f12fcb8e347861a9c.jpg)
![Hardy H2 — is this 3 separated pumps? Hardy H2 — is this 3 separated pumps?](https://www.hearth.com/talk/data/attachments/314/314624-f3dd813b87ff3983a69194ffbc669ffe.jpg)
