Back in the early 1980's, tests were conducted to discover which kind of wood created the most creosote in a regular "open" fireplace. The results were surprising. Contrary to popular opinion, the hardwood's, like oak and madrone, created MORE creosote than the softwoods, like fir and pine. The reason for this, is that if the softwoods are dry, they create a hotter, more intense fire. The draft created by the hotter fire moves the air up the chimney faster! Because it is moving faster, the flue gas does not have as much time to condense as creosote inside the chimney. Also, because the flue gas is hotter: it does not cool down to the condensation point as quickly. On the contrary, the dense hardwood's tend to smolder more, so their flue gas temperature is cooler. Thus, more creosote is able to condense on the surface of the flue. So, saying that "fir builds up more creosote than oak" just isn't true! It is a misunderstanding to think that it's the pitch in wood which causes creosote. It's not the pitch that is the problem, it's the water IN the pitch. Once the water in the wood has evaporated, that pitch becomes high octane fuel! When dry, softwoods burn extremely hot!
What do y'all think about the bolded quote? True or false?
quote taken from :http://www.mastersweep.com/wood.htm
