Isn't that a place in Hawaii?Would they even use fuel bricks there?wxman said:HOWA BOUTA LINKA!
BeGreen said:I would try a single pack at $4.50 + shipping first. Best to find out what is the delivery charge on one ton to your zipcode.
alfio said:BeGreen said:I would try a single pack at $4.50 + shipping first. Best to find out what is the delivery charge on one ton to your zipcode.
Yes begreen; I know what you mean , the shipping would probably kill . the problem is that none of these products are made in the east . Not including the biobricks from CT . they are the closest to my location . It sounds like a good product to me . keep us posted if you try them .
BeGreen said:from the ad:
This item is available for local pickup, or we will get a rate for you for Freight shipment before you bid.
For rates please contact us with the zipcode of your local delivery location (*residential delivery is expensive!)
If you have a local business that will accept a shipment at their loading dock this will make your shipping more reasonable.
alfio said:
BioPellet said:alfio said:
Hey, I sold the guy the briquetting press![]()
Hi, biopellet; did not mean to back stab , but just looking for a chipper alternatives + there made from hard wood , witch is supposedly bater to burn in a wood stove.
BeGreen said:I should add that the night before last we burned the last of the bio-bricks in a different way. As an experiment, I filled the stove with bricks while it was cold. I put in 15 bricks, which made me a bit nervous, because of the potential for a runaway stove with all that fuel. But I packed them in tightly and each row was oriented the opposite of the one below it to reduce air passages between bricks and the layers.
Then I started a small fire with kindling in front of the BioBrick wall. It was slower starting, but after 30 minutes the bricks were starting to burn well in the front middle. However, as Thomas had told me, the stove never went out of control. Within an hour it "looked" like all the bricks on the surface were burning, but the back lower bricks were not. This meant a very controllable fire. I started the fire at 7pm and went to bed at 1 am. The stove was still burning with good secondaries and at 550 at 1am. And when I came down the next morning the heat fan was still spinning and the stove was at 175 degrees. There were lots of coals that started glowing as soon as I opened up the air damper.
I wish I had a recording stove thermometer for these tests, but this is the first time that I have gotten a 5+ hr. sustained over 500 degree fire from compressed fuel without me doing anything more than dampering it down once the fuel is burning strongly and stove temps are over 500. The unique sizing of the BioBricks allows one to pack the stove much better which slows down the burn. Now I if only we can get them made on the left coast....
