I just fixed the oiling problem ( or lack of). I put on the new PLASTIC drive gear, now it oils again. I bought 2 new gears so I can do it again NEXT yr. Now I need to re-grind the bar or buy a new one, BUT I wont need a new bar if I cant get this thing started again
. The past few time I used it I had more and more trouble getting it started, cold or hot. I have heard the ignition module is guaranteed for life if you pay them to replace it. Problem is it don't last long. This saw has only cut about 20 to 30 cords of wood. Its still like new but it dont run like new!!.
If I put some fuel in the carb it starts right up and stays runnin. Shut it off and nothing. It appears to be getting NO gas when trying to start, but once started it runs fine. New plug, air filter and fuel filter. Gas tank is clean as could be. Someone please point me in the right direction. ( not to the junk pile) .I can fix almost any engine, but this one has me stumped.
Mike
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Mike
