Thank you all for your thoughts on the Hampton HI300. I am sold on this product and now just have to determine who I get it from and who I have install it.
I currently have a 25 ft. External Brick Chimney. Two years ago, I had a new 10 x 10" Stainless Steel Liner w/ insulation installed to address cracks in the original clay liner. Judging from the information I have gathered, my best option is probably a 6" flexible stainless steel liner. I don't believe additional insulation should be required. Am I better to get the liner kit available through Hampton, or are there better products and values that will get the job done for less? One of the dealers I spoke with recommended a Magnaflex SS Chimney Liner Kit which is 316Ti (whatever that means). The installer that put my last liner in used a thicker gauge liner and recommends it for this installation. When I asked him why, he said that it would take a more rigorous cleaning if required.
How important is the thickness of the liner I choose? Also, other post indicate that Hampton's liner for this unit is 5 1/2"- not six.
Should I be considering 5 1/2' liners from other companies?
Finally, I read a previous post about block off plates being recommended. I asked an installer about this and I believe what he told me was that he normally installs a masonry collar around the flue connector and then wrap with heat-resistant insulation. Does this sound right?
Appreciate your thoughts.
