Hi folks,
I'm new to this site and considering buying a Hampton HI300 which is the best-looking insert that I have seen having browsed through dozens of web-sites. It appears to get very high ratings from those of you that have purchased.
That being said, I want to make sure it is a good fit for our house in Upstate (almost Canada) NY.
We have a 2,200 sq. ft. two-story center hall colonial home that we had built about 15 years ago. The original floorplan did not call for a fireplace but we had one put in ( masonry hearth and chimney) We use it extensively and I am looking to purchase insert for efficiency ( supplement to oil hot water heat) and to eliminate (or reduce) smoke residue on walls and ceilings.
To get started, here are a couple of questions.
1) Our floor plan is cut-up. The fireplace is located on an outside wall in the family room. Again, this is a center hall colonial with the Kitchen located opposite the family room, and the dining room and parlor located down the hallway in the front of the house. Three bedrooms are located upstairs.
The family room does have a ceiling fan that can be used to push the air down or up. Should this and/or using the two -speed blower fan on the Hampton provide adequate airflow through the house- or will we " burn our faces and freeze our backsides....?"
2) There are a number of dealers in our area- what is a reasonable discount to shoot ?
I am sure I will have more questions in this process- thank you in advance for your help.
