BeGreen said:Can you even get these nowadays? I thought they were very limited in application.
laynes69 said:One night we had loaded the old woodfurnace which was around 6 cu.ft of wood. About 2am I woke to the smell of burning paint. I realized quickly that power was out so I rushed downstairs to check the furnace. I opened the door and the thing was burning white inside. I then realized I had the ash container beside the furnace, So I shoveled a ton of ash on top of the fire and it quickly took care of things.
BrotherBart said:Halon is about as good a way to extinguish you and your family as you can find. You would not believe how fast that stuff will take every bit of oxygen out of a space.
Midalake said:Good God Bartski I think I was refering to a couple of squirts out of an extinguisher not a total room dump system...........
Texas boy said:Midalake said:Good God Bartski I think I was refering to a couple of squirts out of an extinguisher not a total room dump system...........
Bart is right! Halon is NOT a "squirt it on" deal. It's a gas (actually a combination of gasses) and is designed for confined spaces and excludes oxygen thus killing the fire . . . and anything that relies on oxygen for life. It works by instantaneously expanding into the space (including your lungs) and excluding all air. It is heavier than air. There are a number of customizable formulations for this system, depending on what you anticipate being burned in the fire. That's why you'll see several tanks strapped to the wall with the lines running to the ceiling area. That stuff will kill you faster than H2S. We got thorough training on it when I was environmental officer at the IBM in Austin. I knew nothing about it going in, but gained high respect for it coming out. It is an industrial application product and under NO CIRCUMSTANCES should anyone use it in a home setting, assuming you can get it, which I doubt!
Other than that, if you're looking for a very quick way to exit this ol' world, that's it.
PyMS said:Texas boy said:Midalake said:Good God Bartski I think I was refering to a couple of squirts out of an extinguisher not a total room dump system...........
Aww c'mon guys; that is a bit over the top, I believe!
As someone already said, Halon itself is no longer being manufactured and has been replaced with other heavier-than-air fluorocarbons such as FE-241 or HFC-227 (because of environmental considerations, not because of toxicity). These are today still widely used on boats, even small cruising boats, as automatic engine room fire extinguishing installations and, though pricey, are making millions of sailors feel safer rather than threatened with instant extinction.
While it is true, of course, that on the ocean you just don't have the luxury of stepping outside and letting your living quarters burn down until the firefighters arive, it is also true that you don't have many places to go if a really dangerous gas was being released, particularly a heavier-than-air gas that will fill the boat up almost like water.
BrotherBart is right that it replaces air. pretty much like a CO2 fire extinguisher. In fact, fluorocarbon type fire extinguishers are, in and by themselves, no more dangerous than CO2 fire extinguishers. The type of fluorocarbons used have very low toxicity, if at all. Anyone remember the movie "The Abyss"? Although filling your lungs with (super-oxygenated) fluorocarbon liquid in order to dive extremely deep is still science fiction, it is based on a mountain of successful data in animal experiments. So Texas Boy's comparison with hydrogen sulfide (H2S), indeed a very potent poison that can kill at the same sub-ppm levels as hydrogen cyanide (HCN) is a bit over the top, I believe.
When exposed to very hot flames or surfaces, however, most fluorocarbons can release some hydrogen fluoride (HF), as anyone who accidentally overheated/burned some teflon tape (a solid fluorocarbon) and ruined a good pair of glasses because they became etched by HF, should be able to confirm. This is also why refrigeration system installers are being told not to smoke around freon (or its environment-friendly modern replacements), as these are also fluorocarbon gases. No need to worry, however, that a sudden leak in your refrigerator might kill off granny and her cat (although pets as well as people sleeping with their head on the lower rung of a barstool are indeed at somewhat higher risk because of the heavier-than-air nature of fluorocarbon gas, as well as CO2 leaking from the stove ).
Henk
edit: The previous poster is right about the chemical disrupter function of fluorocarbons. This activity follows from the chemical reactivity with flames and very hot surfaces described in my last paragraph. However, it also replaces air, of course.
Texas boy said:The statements made in my post came directly from the info given (and statements made) by the Halon technical trainers when they came to train on our new installations. If the data has been updated or superseded by later data, that info is not in the manuals they provided (which I still have), since there's qute a time lag between then and now! They also showed us real time mortality sequences of mice exposed to the Halon, H2S and interestingly HCN. We watched 'em die (THAT was fun!) to determine the "winner"! The trainer told us that, at the same concentratios, the Halon was faster at extinguishing the mice than either of the other two, not due to toxicity, like HCN and H2S, but from simple air exclusion/suffocation. At the time, I probably did not appreciate such fine points--I just made a note to myself to stay th' heck away from that stuff!! Whether they were correct or not, I have no way on knowing. Maybe they were trying to scare us into extreme caution, since we had so many systems in dozens of confined space areas on the site. Don't know, BUT, in the absence of personal testing experience--any time I see anything that looks like a fire suppression system that uses tanks that remind me of Halon systems, I'm outta there--"over the top" or not! :gulp:
