This stove has a removable portion of the rear baffle which has several drilled holes in it. As far as I can tell, by
looking at the Hearthstone website, this type of baffle was intended to be installed in the HII Alginon stove (the one equipped with a gas burner). For some reason my stove, a wood burner, has this baffle. This removable portion of my baffle is completely burnt through and must be replaced. It does not appear to be easily available from anyplace.
I have a 12" x 12" x 1/4 " piece of plate steel that I am going to try to bend into the correct shape so that it will hang in the still good portion of the rest of this baffle.
Before going to all that hassle, I thought I would post on this forum.
DOES ANYONE KNOW WHERE I MIGHT FIND THIS PIECE?
Thanks
![H II hearthstone (circa 1980s) baffle problem H II hearthstone (circa 1980s) baffle problem](https://www.hearth.com/talk/data/attachments/156/156731-9880a8e521e65029e158ffbc6db1e28d.jpg)
![H II hearthstone (circa 1980s) baffle problem H II hearthstone (circa 1980s) baffle problem](https://www.hearth.com/talk/data/attachments/156/156732-0f06eb329534425d06c15ce7a704af39.jpg)
Thanks
