Is there any good product that you can clean your gutter from the ground? My higheast gutters are 28ft from ground level. I have been paying Randy's gutter 70$ to clean. Doeas a good job but would like to do mine a few times a year.
There used to be a hook type hose extension, you connect to your hose, the it slides to extend at desired lengths. Kind of pressure washes the gutter from on the ground operation.
Forget where I saw it though. Try a search.
Or, just get a 32' ladder and set her up and have at it. Take a bungie cord with ya and strp the ladder to the gutter spike/hanger if your nervous of it sliding.
They make these aluminum 'covers' for your eavestrough. They keep out all the small stuff but still allow water to flow. Also keep ice dams out of the gutters.
No idea how much they cost or what they cost. Saw it on some home improvement show.
I use that cheapo plastic stuff. Keeps out 80% of the leaves. Pain in the butt to clean the other 20%. But now I only have to do it once a year and not three times.
I have read a lot of negative reviews on these, you have to have the perfect shaped gutters for the above to work and all and it gets snagged on a lot of the hangers on gutters... I'd do some research on these if they interest you, or buy it from a place with a good return policy.
I'm lucky as I live in a ranch with easy access to the roof. I can use a basic stepladder in the back and the front I use a extension ladder in it's lowest setting. I can do my gutters in like 15 minutes! Sometimes I'll use my electric air blower to get the corners which are farther than I can reach easily though.
My aunt has those metal ones and they work great. Gutters are great for re directing water out of your cellar sure they're a pain to clean the leaves out of them...but water in the basement can be a bigger problem.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
