Guidance on Stove Installation in Shop
Englander2000
2
USA
Hello and thanks in advance for your help.
I am looking to install a wood stove in my shop.
The shop is approximately 16 feet tall.
There is a loft I will need to go through that is approximately 7.5 feet off the ground.
I am looking to use a ceiling support box and I am not sure where to install it.
Do I install it closer to the roof of the shop (there is just open trusses) or do I install it through the floor of the loft?
Could I cut out a big enough(19 inch) hole in the loft floor and use double wall pipe until I get to my trusses then use the ceiling support box and run triple wall the rest of the way through the roof?
  • [Hearth.com] Guidance on Stove Installation in Shop
Code says the ceiling support box is to be installed at the first floor penetration, & Class A chimney is required from there to the cap.
