Hi all,
its not mine,I have a,new Harman pellet stove,XXV works great.
My neighbor also went with a new heating system this year.He just installed a Greenwood 200 and is having problems;
Lots of smoke when he opens door to load wood.
Also seems to build up a lot of creasote in flue and vent pipes as well as inside firebox(above on the excahnger tubes(?)).
We installed a "draft inducer" last night and it did help a bit but still has smoke when he loaded it.
Thanks in adavnce for any help,also happy to give more info on system if needed
 If his weather was anything like upstate NY yesterday, three small ROUNDS in the back of the box would probably produce usable heat for 8 hours. Do not use splits. 'Be very careful to keep the surface area to mass ratio as low as possible' That's technical speak for using small loads of quality +6" rounds.
