!! I am a cheapo do it yourselfer Mainer and I just cant drop $700.00 for a set of paper prints. I understand he has a lot of time and money invested in the design, but come on $700.00
machinistbcb said:I did notice that the fire tube seems to be top secret. It is not pitcured anywhere On Fred seton site or the green fire site ethier. But one could use their imagination anf figure it out pretty easy. My problem with buying the plans from Seton is the price 700.00!! I am a cheapo do it yourselfer Mainer and I just cant drop $700.00 for a set of paper prints. I understand he has a lot of time and money invested in the design, but come on $700.00
questions:
1. does greenfire have ash pan on bottom?
2. does greenfire have steel reinforced refractory like seton?
3. did you pay less the way you did it not 100% completed?
4. did they give you the sealant for final build?
5. does the door have refractory on it?
6. how thick is the refractory pieces?
7 how thick is the other insulation?
I went to the plumbing shop and grabbed all the fittings before I started. At the end I was short 1 male to female adapter. I will do that in the a.m. In the meantime if it pops it is in a safe place. Also, you are correct, the vessel comes with supply and return piping. No place to screw in sensors or samson. The manifold is my creation. I put the aquastats very close to the supply outlet. The way this vessle is made, heat transfers quite well that close to the outlet piping. When the system is cold the aquastats lag by about 10*. Once everything is warmed up all the temps seem to correspond across the system. The samson may have a bit temp. difference but it is located in the supply stream so it is pretty close to accurate... Eventhough you cant see it I have 2 aquastats. 1 for circ. between boilers and one for overheat control. I also have a temp relief bypass for a dump zone if the temp goes over 210*We use essential cookies to make this site work, and optional cookies to enhance your experience.
