Wondering if anyone here knows how bad this might be or what I can do to check. I've heard it both ways that green grass on your drain field is a bad sign but also told from some that it is a sign everything is working as it should. The green grass starts at the edge of the tank.
![IMG_1128.jpg IMG_1128.jpg](https://www.hearth.com/talk/data/attachments/298/298861-5d15bd7449934d9e900fb29182ec9088.jpg)
House was built in 1974 of course the septic was installed then too and as you can see with the attached as built diagram it's not the greatest. Although I am pretty sure that someone has in the past changed or added to the field from some telltale signs around the property. I had it pumped last October after 5 years of use and the pumper dude was hesitant to take my money to pump it because of how it was working. Said it had hardly any sludge for the time between pumping's and could go at least another 2 years in his opinion. I had him pump it anyway as I wanted to install a riser on the tank, and he was already here. No slow drains or gurgling of any kind.
From what I can remember this grass area has always been greener since we have lived here. But our backyard neighbor insists that this is a sign that it is failing. The area has settled a bit. The area is not saturated with water or spongy. He and the other backyard neighbor replaced theirs a few years ago and our next door neighbor just finished getting a new drain field installed two weeks ago because of failure.
The outlet of the tank I dug down to I did find a slight leak on the lower part of the PVC pipe that I was told I could use hydraulic cement on to seal it up. Going to do that in the next couple of days.
![IMG_1130.jpg IMG_1130.jpg](https://www.hearth.com/talk/data/attachments/298/298862-822392366629946595a7040346231e5e.jpg)
So, I dug a hole in the middle of this patch and found a line. Our soil is very sandy like and while the soil was darker like it was wet it too wasn't saturated. The pipe in this area is white solid pvc.
![Grass is always greener...... Over septic drain field? Grass is always greener...... Over septic drain field?](https://www.hearth.com/talk/data/attachments/298/298860-9e5682a947a02d2557c88e70add8bb47.jpg)
So, I then dug a hole right where the green ends and dead grass starts. This area had whatever fabric they use plus rock inside. Dry soil.
Dug a hole in between the two and reached the pipe again. Also wrapped in the fabric but no rock and the pipe seem similar to the kind that has the holes in it for drain fields. I am not sure if it is, but I can squeeze it unlike pvc.
![IMG_1133.jpg IMG_1133.jpg](https://www.hearth.com/talk/data/attachments/298/298863-3898785120af80cd92e1a0ff6e57aed2.jpg)
I do realize that the play area is probably in a bad spot but as you can see from the as built the tank is on the opposite side of the house. I assumed that somehow it got flipped or changed because I could always see the slight depression in the ground of the lines.
Just wondering if I should do more digging and investigating or patch the leak at the tank and wait since we have no other signs or issues right now. I do know that there is wisteria growing all over in this area from the previous owners who had a giant one in the back yard that I removed (well above ground at least as I still find some sprouting up now and then.) The concern I have is that there is a solid PVC pipe or should be solid in most of this green area.
![1662686480185.png 1662686480185.png](https://www.hearth.com/talk/data/attachments/298/298858-f700bdd03a87370ed3dd362a212d71ae.jpg)
