grapple load delivery - how much work do I have ahead of me?
Average time to cut/split/stack a single cord of firewood once it's onsite?
  • Total voters
    44
twd000
448
Southern New Hampshire
finally got my hands on a grapple load of hardwood delivered last week. Mix of birch, beech, and maple. He claims 7-9 cords yield; I'm thinking it's on the high end of that. $900 delivered, compared to $250/cord cut and split around here. Most of it is 10-14" diameter which should make it easier to handle. I'll be keeping track of how many hours it takes me to process, to see if the savings is worth it. Has anyone estimated how many hours to cut and split a cord with power equipment? Handling and transport should be minimal; the drop pile is within 20 feet of my stacks.
[Hearth.com] grapple load delivery - how much work do I have ahead of me?
Wow when you go big you go big!!!! Looks awesome....
Reactions: twd000
I'd put it to you this way, it would take me 2 days of cutting 6-8 hours each day to get every piece cut to 20" lengths, then figure 2 hours a cord, I would say 3 - 4 (8) hour Saturdays & Sundays cut, split, stacked working by your self.
Also this isn't a race, pick and choose your logs carefully while cutting, a log falling from the pile can cause a serious crushing injury, even at 10" diameter, green wood weighs a ton.
yeah I'm cutting off the overhanging ends first, then working the stable pieces down from the top. I've already had the pile shift on me once
How are you going to calculate the cost of the cutting,splitting,fuel etc ?
bob
I think there is alotta work there..........More than a day
I voted <1 hour.. because I'm superman lol
Really though.. think about getting a cant/ peavey hook for moving those around/ pulling them off the top of the pile when you start to get into the middle. It makes life soooo much easier.
I got a grapple load similar to that delivered here last summer.. about 1/3 of it is still in log form. I had more larger logs though.. kinda wish they looked more like yours. A few beech ones I had were 24"ish diameter, and a groan to move/ split.
Great looking load there. I'd certainly pay 900 for that. Logs are a great size for processing. I have no idea how long it will take, but I look at processing as a great source of exercise, and excuse to be outside, and way to provide for the family by investing my labor into keeping the house warm. I'd say you're ahead vs. c/s.
Get a cant hook or peavey, a tow strap to pull logs off the pile, and a way to mark them. I use a yardstick and the spray paint for marking lines (works upside down)
Pull a few down and space them a few feet apart, 3 logs is my suggestion. Then mark them all. Then cut all 3 logs about 80% thru. Grab your peavey or cant hook and flip them. Cut the remaining bit. You will be surprised how fast you tear thru them like that. If you have help you can have a person marking and flipping.
I'd love to attack a pile again. I enjoyed every minute of it. I wouldn't even dick around cutting off ends. I'd just pull em, cut em, roll em, finish em..repeat until done.
Easy. 6-8" rounds. I would split most of it once. Some of the small stuff not split at all. And a little two splits. But I like my stuff large.
Reactions: heavy hammer
Does anyone have experience using this type of timberjack?:
http://www.northerntool.com/shop/tools/product_200640336_200640336
I see some reviews stating that it doesn't grab onto small diameter logs. As you can see, most of the stuff I have is 10-14" diameter. They are heavy due to length, not diameter. I want to be able to roll logs off the pile onto the ground, then prop them off the ground to avoid binding the chain when I cut.
Nice pile have fun, cut and split away!
Great tool - get the fiberglass handle model. It costs as much to replace a wooden handle as it is to buy a new jack.
bob
does ''grapple'' in new England mean triaxle? here in PA we say ''triaxle load'' not grapple load. . . . it confused me hahahaha
Here in Ontario we call it a Tendon load All the same load
just different names
Yes. I own the big and small one. They are great. I can handle all reasonable tree sizes and have yet to bend or damage one. They are modular too so, if you do break something, you can just replace the part.
I have that one. You can't grab smaller than 7 inch logs. Take the jack part off you don't need it. You don't need to put the logs in the air you really just want to roll them.
