Grandpa Top Vent in Fireplace of Old Mill
mavericks99
1
Philadelphia, PA
First, this site has taught me a lot in a short period of time, so thanks. I purchased a Grandpa top vent wood stove (photo shows the stove when I moved it in today before I removed the log lighter bar to slide it back), which I would like to use as a slammer in my old mill (cir. 1787). Basically, there are about 3-4 months where I need help heating the large open area of the mill. I will move it out in the spring and revert to gas log lighter bar and ambiance fires.
The fireplace opening is large (52" wide x 37" tall and 37" deep), with a 25" brick hearth. The chimney about 60' high and draws great. The fireplace's steel damper opening is 6". I would plan to push the stove into the fireplace and let it rip, but I want to know what else I can do here. The chimney did not get much use and is in great shape. I am ok with pushing the boundaries here. Not a single thing about this mill is to code, except maybe the 3' thick fieldstone walls.
I'd love any insight you can share, recognizing that this is not my home, fires will not be left unattended and I am a cowboy. Thanks in advance for your time and suggestions, Ed
  • [Hearth.com] Grandpa Top Vent in Fireplace of Old Mill
No picture and with that fireplace you probably don't need to make a gap because the fireplace should handle heat well. Wrap a fire proof with 2 layers of material around the stove. Use small fans to push air into the middle and a couple more to push stove heat and heat coming from wrapping into the room. Computer fans are inexpensive and will stand some heat as long as they aren't close enough to char or flame up. We raised limosin out here but lost the cattleman instinct after replacement bull blew through holding pen before chute and squeeze. Next he chased me around barnyard, caught me and put a horn into my thigh to toss me over manger into the barn. Landed head first on oak desk I was storing there. He went to auction the next day. Hereford cattle are easier to deal with. Now it is leased out to longtime friends who've raised cattle most of their lives. He gets use of 2 barns and 30+ acres of decent hay fields.
