I believe it’s the Grandpa series of the fisher stoves. Double arched doors they are missing. Anyone know where to find replacement doors?
Thank you for the information. I did measure the opening but missed the part about the hinges. 21x 11 roughly is the opening. I will have to get back to the stove to get the other for you.I can direct you to the person that would have what you need, but I need more information about the stove to be sure of the model. A few people across the country have different doors.
First, I assume there is no UL tag that would have the model marked on the tag.
The door opening size for Grandma will be 17 wide X 10 1/2 inches high. (and uses 5 bricks across the back)
Grandpa door opening will be 21 wide X 11 high. (and uses 6 bricks across the back)
Did you have the doors at one time or what makes you think they were arched top?
Once we know if it is a Grandma or Grandpa, we can figure out if it is a Series I, II or III and which doors it had.
Pictures would help. Glass door stoves had air intakes on the sides of stove, XL is a brick wider than Grandpa and is the only stove body with an arched door opening at the top. If it needs arched top doors, you have a choice of black, nickel or brass plate.
If you never had doors;
If you give me the measurements from center of the top door hinge plate to the center of bottom door hinge plate, I can tell you if it had flat top or Cathedral doors. That is the only way you can tell what it had, the door opening and channel iron (door seal) is the same size opening for flat and arched doors. Only the hinge placement is different.
When you find doors for the correct model, don't expect them to fit on the hinges as welded onto the stove. You can't change doors from one stove to another. There were many patterns at many foundries for doors which are all slightly different. The stove was sat on its back and the doors are placed, centered, on the door seal, closed. The hinge plates were then tacked in place and the doors are tried for operation. If correct, the hinge plates were fully welded. So when changing doors you normally need to cut the hinge plates off and reweld in the proper position for different doors. This is due to the hinge ears on the doors being different from each mold. They will usually bind really nasty and not close, or not be centered on the door seal. Others may not contact the door seal at all. They must make contact in 3 areas all the way around to seal which can only be done by placing the door hinges exactly where they need to be for each door. (while also centered on door seal)
