Hey all, new here in hopes someone can shed some light on my situation. I just bought a grandma bear. Seemed to be in decent shape other than some firebrick and a loose door, which I attributed to the lack of gasket while I was inspecting this stove on sight. It wasn't until I got the stove home and read on this forum that I realized these stoves aren't designed for a gasket. There was some leftover gasket on the stove. Anyways, as you can see in the pictures, the door isn't even close to sealing and all I can think of is that the door is warped. I did heat and bend the latch but that didn't make a difference.
The latch door barely makes contact, and because of this the left door is loose when they are closed together.
You should be able to see the Elmers Glue I used to identify where the door is making contact... On the outside inner channel on the stove. I put glue on the door and what you're seeing on the stove is where it made contact.
I did wire wheel all of the channels clean. I've given the door pins a good look and they seem to be in decent shape, a little bit of play but nothing too concerning. I have a Poppa Bear right next to it that seals great with similar play in the hinges.
How can I verify if the door is warped? Does anyone have any other thoughts?
