I will not bother posting photo's, plenty have been posted in other threads and there was no real dfference.
I was pretty much sold, I did quiz the owners.
They wish they had put in electrical back-up, something I intend to do.
They were having to fill it every couple of hours. But were using green wood, they had not stocked up, did comment on how much quicker it came up to temperature with dry wood.
They were using Propane forced air as back up, a pre existing system.
They have vertical exhaust, the installer mentioned that this was a new design variant, not as shown in the manuals, it was installed last November.
They had space limitations, we have an old root cellar to rebuild, 16ft x 32ft, which I intend to make into our plant room.
So current plans are:
WHS 2000 with ultimate electric back up.
Backed up/supplememted by Froling (or Windhager if they come to the US) pellet boiler with a hopper.
At a later point I would like to add Solar - evacuated tubes.
This way we should get enough heat to stop the building freezing just using the pellet boiler when we are not around, we will be using Glycol, probably 70/30 for disitibution. We have had minor electricty failures, so need to look at the cost/practicality of propane generator.
The SWMBO came along, she like most I guess is much easier persuaded of the logic by the pro's. She played around with the door, saw no issue loading it, just not regularly.
