After much watching on Facebook Marketplace, I finally spotted a bargain splitter--a DHT 22 Ton. Quite a drive (2 hrs)
When I got there, there were pieces on the ground around the splitter--I debated hopping back in the truck, but decided that it was fairly new, and probably worth buying--but since the part that was on the ground was the start rope assembly, it meant that I had to buy it without starting it.
Ordered the new pull rope assembly it needed--put that on late yesterday, drained the gas from the tank and topped up the oil--not even a cough.
Today I got serious--took the carb off--sure enough, white slime and rust from ethanol gas, so I cleaned everything up, cleaned out the jets and passage ways and reassembled. It started, ran for maybe 10 minutes and quit, bucking and smoking. Took everything apart a second time and recleaned the whole carb, Second time, no joy, but i had a gas leak. Third time back together, and it started and ran for at least 15 mins. I shut it off, had lunch and it started up again after lunch. I may still put a carb kit on it, but I'm pretty tickled to have a working splitter. But it is going to rain more today and tomorrow, so it looks like Sunday will be the real test.
I'm in to it for $530 plus a tank of gas, so I think I did OK...
