Hi! Let me start out by saying I AM NOT a plumber/heater. I am an electrician. My best friend is a plumber/heater but he has very little experience with solid fuel boilers. He is helping me with the whole system but is uncomfortable trying to come up with a solution that will do what I am trying to do.
I finally got a (new to me) wood boiler. It is a Buderus g201 in great shape. I know I have read that it is more of a coal boiler for for $300 and the shape it is in I figured it was a good one to start with.
With that being said, I am building a house mostly out of pocket so I do not have a ton of funds available to buy new fancy equipment.
Here is what I am trying to do; I have a 2600 sqft ranch (counting 1st floor only, not the basement). It has radiant in the slab and 1st floor. I currently have an oil boiler running the radiant. I have not got my DHW setup yet but plan to use a Indirect tank so I can use the wood boiler to assist with heating it. That is where the catch is with plumbing and control...
I do not have thermal storage yet but plan to get something (not sure what yet...). With the radiant I can use the storage water down to 100F (plus/minus). For the DHW obviously that wont work.
I DO NOT WANT the oil boiler to heat the thermal storage, and it has to be automatic because I am gone most weekends in the winter and need the oil boiler to automatically kick in when the wood boiler cools.
Most of the diagrams I have found appear to do 2 things:
1) the petroleum boiler heats the storage (or...)
2) the wood boiler hot water is just teed into the oil boiler hot water. I don't this I want that setup because if it needs to heat the water up a few more degrees for DHW it can if it goes through the oil boiler first....?
If my storage is 'say' 110F when the radiant calls for heat I want the system to pull of the tank until it cant any longer. The issue arises when the DHW calls and the storage is still only 110F then it needs to fire up the oil boiler to heat the water up.
I would somehow have to have a control setup to make it all work, but I haven't worked that out yet. I am thinking I will need a relay and aquastat so if just the radiant calls and the storage is above 100F the oil boiler wont fire. But if the storage is below 100F or DHW calls and the storage is below 140F the oil boiler fires. Obviously I need to control a valve going to storage as well that closes when the the wood boiler cools off.
I figured if the storage feeds the cold water supply of the oil boiler with a diverter valve then the oil boiler would only have to heat the water from 110F.
I attached an original diagram that I found on Tarm's website. Then I edited it how I thought I could make this work. Now I am looking for all your input and critiquing!!
Fire away! Tell me if this will work and what is wrong.
![Got a wood Boiler.... how to plumb/control it with radiant & DHW & Storage Got a wood Boiler.... how to plumb/control it with radiant & DHW & Storage](https://www.hearth.com/talk/data/attachments/298/298164-0e6841a727abd43a8440e3c9f33eab73.jpg)
![Got a wood Boiler.... how to plumb/control it with radiant & DHW & Storage Got a wood Boiler.... how to plumb/control it with radiant & DHW & Storage](https://www.hearth.com/talk/data/attachments/298/298162-82db121cb8dcc9f0b98a773583296ae2.jpg)
