Background:
This farmer cash crops his own land and does custom tillage, manure hauling, harvesting and commodity handling for other farms all over Northern Michigan. He has an 8,500 sq ft heated maintenance/repair shop to service his machinery. The back part, which is over 13,000 sq ft was not heated and was used simply as parking area for all the tractors, harvesters and implements.
The business has grown to the point where they can not cycle all the machines and tractors through the existing heated area during winter downtime. He needed more space so they ripped the concrete out of the back area and hired us to heat it.
(NOTE: Always put insulation and tube in cement even if you'll "never" heat it)
We put down 2" of foam under the slab and the same on the edge, placed about 14,000 ft of 3/4" pex in 3 zones and they poured 6" of new cement on it about 6 weeks ago.
The current 8,500 was heated with radiant floor and btu's are generated with a 7260 Central Boiler. Despite being well insulated, they have always had difficulty maintaining temp in that area, partly due to the piping and tube arrangement and partly due to lack of output from the Central. Last winter they went through 5 or 6 semi loads of wood and the shop was rarely above 60*.
We went through a number of heating options including more efficient wood burners, waste oil boilers, LP gas, water to water heat pumps and pellets and came to the conclusion that pellet boiler(s) with automated feed made the most sense and offered the quickest ROI.
His main issue with wood burning was the labor involved. When outdoor temps were at 10* or less, the Central had to be tended every 4 hours, even during the night. If they missed the 2AM "feeding" it would take all the next day to bring the water temp back up. The thought of heating all that additional space even with an efficient wood boiler system sounded like far too much labor. Processing and handling what would figure out to be around 70-80 cords of wood demands at least one full time employee. Didn't want to go there.
So we went with the new XL series Windhagers. 3 of 'em.
The boilers came in the 13th and we spent most of the 17th hauling them and other materials to the job site. (Deer season opener got in the middle of that...........)
The Windhagers are very heavy. shipping weight for 4 of them was 11,500 pounds! Getting them off the pallets and set on the floor made me glad to have a Matt. Everyone should have a Matt when moving heavy stuff.![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
Marc Caluwe had called and said Martin Westermayer, Windhager's field service tech was in the US and wanted to help with installation, set up and commissioning. They were coming the 19th so it was pedal to the metal, 16 hour days Monday and Tuesday getting started. Martin and Marc showed up Wednesday afternoon and stayed at my place until Saturday. In between handling all their other phone calls and e-mails they pitched right in and helped make things go exceedingly well........Thanks to both of you![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
We wanted to get the boilers piped and fired by Friday night and we managed to do that. It was amazing to see something that size putting out <50ppm CO and efficiency in the 84-86% range.
![Got a little project going this week........ Got a little project going this week........](https://www.hearth.com/talk/data/attachments/145/145437-e726edeaf1ab6b2572ca76218c65bb48.jpg)
![Got a little project going this week........ Got a little project going this week........](https://www.hearth.com/talk/data/attachments/145/145442-fa6c36ba076908b146fa20667c69b452.jpg)
![Got a little project going this week........ Got a little project going this week........](https://www.hearth.com/talk/data/attachments/145/145439-e7ac6fb4b64f66a22f6627b474e01655.jpg)
![Got a little project going this week........ Got a little project going this week........](https://www.hearth.com/talk/data/attachments/145/145440-6444e0f0c96e4cc91790f0254c86e72e.jpg)
1st picture: My boys doing what they do.
2nd Picture: 3 pick up heads bolted to the floor in the bulk bin. I sized it to hold a usable quantity of 10-11 tons.
3rd picture: Matt. Everyone needs a Matt when the steel get to 2" and pipe wrenches are a yard long.
4th picture. L-R Andy Ebels (Head pipe fitter for Ebels Heating), Martin Westermayer (the European Standard), Marc Caluwe, (AKA Mr Windhager himself.)
Note: If you ever run into Martin someday, do not mention steak to him. You'll wind up buying him one.![Wink ;) ;)](/talk/styles/default/xenforo/smileys/wink.gif)
